What temp thermostat is everyone running? My 68 has a 302 out of a 72 Torino and a 195 thermostat which seems to be a bit high. I was considering put in a 170 or 180.
Engine Temp, what thermostat?
Re: Engine Temp, what thermostat?
Originally posted by LKV76 View PostWhat temp thermostat is everyone running? My 68 has a 302 out of a 72 Torino and a 195 thermostat which seems to be a bit high. I was considering put in a 170 or 180.6 jeeps 2a-cj5. bronco now. 70,efi 302,c4,ps,pb, 4.56's detroit's 2bl,4.5 rollin on 37's
Not exactly sure which thermostat came in my crate motor, but my temp never rises above 170. My engine seems to run great at that temp.1970 Bronco
Originally posted by CityHick View PostNot exactly sure which thermostat came in my crate motor, but my temp never rises above 170. My engine seems to run great at that temp.6 jeeps 2a-cj5. bronco now. 70,efi 302,c4,ps,pb, 4.56's detroit's 2bl,4.5 rollin on 37's
i run 195 'cause you need it for efi but on a carb engine i would run a 180Last edited by Rockbronco67; 06-26-2009, 10:46 AM.
mine runs 200-205 with electric fan and aluminum rad .c4 auto. i'm going to run a remote fan cooled trans cooler to dump the hot trans fluid out of the rad.6 jeeps 2a-cj5. bronco now. 70,efi 302,c4,ps,pb, 4.56's detroit's 2bl,4.5 rollin on 37's
Mine wants to climb up to 210 215 idleing up the trail but will cool down if i bump the idle up, Put a new 180 high flow thermo and a flo kooler water pump and a 55 gallon drum of water wetter and it still wants to get up there, sooo getting rid of the flex fan and going steel ridged and a new shroud, hopefully this will help!!!!!sigpic
I changed my thermostat to a 160 and took it for a drive. It climbed to 200 on the highway and 210 on the trails. Air temp in the low 80's. I have a new high flow water pump but stock rad. I am planning on putting in a fan shroud and hopefully that will help. If not the next step is a new rad.76 302 C4 3 1/2 on 33's
68 302 435 5 1/2 + 2 BL on 35's Locked 44 and 9
I have been told that 195 is just the car companies stickin to the safe zone, that some more power can be squeezed out of an engine at a little higher but provisions have to be made with Higher PSI caps etc.
