Well while removing my steering column extension from the column to the steering box I found out that the lower bearing in the steering column is loose. There is no balls in the bearing! I have never tried to remove the bearing before. Any advise? Not sure how to get the rag joint end off the shaft either.
Thanks in advanced,
PS I did a search and found nothing.
Thanks in advanced,
