I posted a previous issue with gas not being pulled from the aux tank, and it is now affecting the main tank. If the bronco has been sitting the fule filter immediately fills with fuel as normal but after 1-2 minutes the engine drains that gas and from then on I can only see small amounts of fuel entering the filter or sporadically shooting into the filter.
The bronco has two tanks and I was switching the selector valve between the two tanks... any ideas as to what could be causing the low fuel flow? I am thinking the valve may be clogged, any advice on how to correct this? It also has a fuel flow when the switch is in the off position....
