what sized ram?
  • what sized ram?
    Ram on Pirate.
    It is. 1.5 bore 6" stroke with hoses for 125. Is this the rigjt size, and is it a good deal?
    Thanks.
    Re: what sized ram?
    Mines an 8" and I use every bit of it.
      Re: what sized ram?
      You'll want an 8 inch stroke. (that what she said) LOL.
        Re: what sized ram?
        Speak for yourselves you perverts...
        I have read that the Surplus City rams are a great affordable option. Like this one. Would it work?
        https://www.surpluscenter.com/item.a...7258-8&catname=
        Also, 3/8's hydraulic line or 5/16th?
        Thanks!
          Re: what sized ram?
          Not to highjack, but what are you guys doing for a steering gear? Can the stock power steering gear be drilled and tapped for ram assist, or will I have to buy the custom PSC bronco box?
            Re: what sized ram?
            I sent my box in to pcs and they ported it, but it was not the stock box.
            1971 BRONCO, 89 5.0 HO, NP435, D20, D44 CTM Superior Detroit , Currie big bearing housing 31 spline Detroit
              Re: what sized ram?
              4x4x2 box sent to west texas offroad..
              KK6DAD
                Re: what sized ram?
                8" ram
                that ram might work, but for a little more you can get the real deal, http://www.pscmotorsports.com/sc2200...der-p-552.html
                PSC all the way for a port and tap.
                  Re: what sized ram?
                  That's what I have. SWEET
                    Re: what sized ram?
                    The psc 1.75 inch ram seems to be the best for assist.
                    The surplus city rams work but they are all in the 2 inch size range. This makes them just a little slow to react on the road.
                    You need and 8 inch stroke.
                    I have a 1.5 on mine and it bent stupid easy.
                      Re: what sized ram?
                      i have learned 8" works for big tires than 1.5 would work and works if you are driving on street too....if only off road more than go with 2".
                      What can I fix next?
                        Re: what sized ram?
                        I cant remember how much stroke I have but I know its a PSC 1.75 ram. Gonna have my spare EB box rebuilt and tapped along running a PSC Pump and res.
                          Re: what sized ram?
                          I have a 2" ram with 8" of stroke and it works fine on the street. I think I need a bigger pump to get the full use of it off road. Don't forget to pull the steering stops they may limit travel but either way I want a ram that has less movement then my front end.
                          FM <><
