Twin stick
  • Twin stick
    OK now that I have gotten and installed my stainless steel twin stick for the 20 just how does the gear selection go when shifting?
    As well, I imagine trans must be in nuetral or park as well?
    OK. Depending on whether or not you have a tshift or J shift
    Right Stick:
    Rear Low
    Neutral
    Rear High
    Left stick:
    Front Low
    Neutral
    Front High
    Jshift options:
    Front low:
    Rear in neutral
    Front in low
    T Shift optionsinternal tcase modifications required for this)
    Rear Low:
    Rear in low
    Front in neutral
    Remember you need to shift the front in first when going to low, and the rear in first when going into high. You will get the feel, but for example, you can not move the front from high into low with the rear in high. You need to shift the rear into neutral
      Looks like I'll have to play some to get it all figured out, damn interlock pills!
        Easy to fix, grind your rails
