NP 435 Question
  • NP 435 Question
    Hey All,
    Is there any prob with swapping out a "tall" shift tower with a "short" one on my NP435?
    TIA
    Sean
    '88 347 roller, Exploder EFI, WH Shorties, NP435, twin stick D-20 with Tera lows, 44 4:56's w/ARB chromos and CTMs, 9" Detroit, cust dash, wiring and STILL ALMOST "DONE"!...
    Re: NP 435 Question
    You mean the whole top cover?
    I don't think so, I think the Tall and Short shifters are because of a difference in the cover.
      Re: NP 435 Question
      If there is no difference in the shift forks (length and so on). I don't see why not. Don't know if you can put your old forks into the new tower, wouldn't think so.
      My opinion on limmited knowledge/ disclamer off.
      1970 w/89 5.0, np 435/203/205, 456/locker/ARB, 4 wheel disc brakes w/hydroboost, 5.5" lift w/ext.radius arms, 3" bod lift, RS 9000's, tilt column, Hydro assist steering, 39.5" pitbull's on H1's. 4 link rear suspension. Hey brother, can you spare some change, I need parts....
        Re: NP 435 Question
        Thanks guys, now, does anyone know where to find the stock pigtail and terminal that fits the b/up lite switch? I know I can solder two wires on there, but was trying to go OEM if I could.
        Sean
          Re: NP 435 Question
          I remember seeing one offered in one of the early bronco catalogs. I need one so I'll look for it.
          sigpic70w/ 69/351w/GT40 lightning heads 435/203/D20 5.5/3in 44/arb 9in/detroit need some beadlocks
            Re: NP 435 Question
            Sean, are you ditching the body lift or what?
            About the reverse switch pigtail, it isn't fancy but I just used normal old crimp connectors to push onto the spade connectors on the switch.
              Re: NP 435 Question
              Not yet. I kinda got a little A.R. when I did my wiring awhile ago and I never had a b/up lite switch on my tranny. I came across a deal and trading mine out. I found the stock connector, but the friggin' thing is $23 shipped, so considering my options.
              Did you solder the spade to the switch?
                Re: NP 435 Question
                My reverse light switch has two male spade connectors coming out of it. I crimped on two female connectors to the wires, then loomed and shrink wrapped them back to a weatherpack connector on my harness. Its not the cleanest method but it does work. $23 seems a bit high for a special connector that you never see, IMHO. I do understand though...
                  Re: NP 435 Question
                  Yup, got it. My switch has 2 pin connectors.
