I know that there has been alot of axle swap done like this one.Any Info would help...I got a good deal on a set of 78 full size Bronco axle FRT and REAR.....1 How much wider are they then the axles out of a 72 Bronco...2 What are the good and bad of the full size....3 Any mock up on the frt axle I now that I will have to put new pads on rear axle....4 What are a set of 72 Bronco axle going for (Disk Front and small bearing 9in rear with spool and 3.50 gears..Thanks Dustin....Or just run some 60s Front and Rear ...I have Bulit 302 NP 435 Dana 20
![Givemebeer](https://www.norcalbroncos.com/forum/core/images/smilies/givemebeer.gif)
