9" Pinion Guard
  • 9" Pinion Guard
    Getting the third ready to go in. What are the thoughts on pinion guards? I haven't had a problem without one, but one never knows.
    What are you running, if anything?
    Re: 9" Pinion Guard
    I got one from Great Lake Offroad. I have never run one but when I was working on the rear end, I figured I would add one...
    I did scrape it up a bit last week so it is probably cheap insurance.
    The GLO guard is very nice and reasonably priced.
    71 Bronco
    EFI, ZF, Atlas 4.3, 35" BFG's, Explorer serp, hydroboost, 4 wheel disks, Lars Bars, Protofab bumpers, Warn winch,
    Mastercraft seats.
    Build thread
    ZF swap
      Re: 9" Pinion Guard
      i have the same on and it works out great, I have hit it a couple of times.
      1971 BRONCO, 89 5.0 HO, NP435, D20, D44 CTM Superior Detroit , Currie big bearing housing 31 spline Detroit
        Re: 9" Pinion Guard
        cheap insurance. Might as well.
          Re: 9" Pinion Guard
          I use my pinion yoke for traction. No guard here.
            Re: 9" Pinion Guard
            I've been dragging and bumping my housing, and now it has a slow leak around the rear facing perimeter weld.
              Re: 9" Pinion Guard
              I run the James Duff diff/pinion guard. It likely saved me from cracking my rear diff open 4 times on the 'con over the weekend. You lose a little clearance but gain a lot of protection. I like it.
              I am sure some of my hits were due to my inexperience in the driver's seat...
                Re: 9" Pinion Guard
                Love my pinion guard. make sure you get one that does not take away clearance. forgot were i got mine.. but its the round pipe kind.
                KK6DAD
                  Re: 9" Pinion Guard
                  DIY makes a nice one. Open to keep sand and mud from caking up around your pinion. Heavy duty and no ground clearance lost.
                  sigpic70w/ 69/351w/GT40 lightning heads 435/203/D20 5.5/3in 44/arb 9in/detroit need some beadlocks
