Hi guys , these are the pics of my arms. I basically went by the article in bronco driver. I have since cut and modified the arms to add some camber and angle out since I lengthend them 10 1/2''.I started with the stock arms and then added the extentions sold by bent and twisted,then boxed the whole thing with 2x3 angle iron, then I cut out some cardboard patterns of the area at the very front on the arms and filled that area with 1/4'' thick plate.After I mounted them on the truck I had a terrible angle on my lower coil bucket brackets so I cut the arms in half about an inch behind the lower shock mount.Confused yet? Then got the angle I wanted and welded and gusseted It all together.I'll post pics of the new and improved arms if anybody is interested. E-mail me if you have any questions
extended and boxed radius arms
When iinitially extended my radius arms I made one mistake that you did not make here. I stopped the plating at the C. A few years back on the con one of my radius arms broke completely off at the C and the othr was on its way. You probably won't have a problem, but you might wanna ad a gusset for shits and giggles.
The arms look great!!“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
