LED lights
  • LED lights
    anyone running LED's for lighting? Was thinking about going that route.
    Re: LED lights
    I put LED side marker lights on...
      Re: LED lights
      I've been experimenting with cheap LED lights from AutoZone as rock lights. Found a couple fixtures that might fit the bill, but stilil experimenting.
        Re: LED lights
        Tony and I run them for rock lights. Shop around, some are cheap and dim,some are much brighter for not much more $ love them though
          Re: LED lights
          Check these out I saw them on extreme 4x4.They have a true 180 deg dome light distribution and are very bright.There are a few different colors as well.
          http://www.roundeyes.com/featured.html
            Re: LED lights
            I kinda like the old school look how the entire lens lights up, does the LED just light up a little spot on the lens?
            __________________
            '67 EB, 5.0 EFI w/ Explorer Serp, 3 1/2" Lift, 1" Body Lift, Chevy Disc, Crab Family Cage, Future Plans: NV3550, Paint
            ECV
              Re: LED lights
              I have not seen them in person but they appear to glow compared to standard a standard led.I want to put red courtesy lights inside.While experimenting I found that typically I didn't care for the red spotlight look that the led makes.roundeyes said that I bulb would light up the entire cab.
                Re: LED lights
                KWSPony, I am so glad you are figuring all this out. I will need it someday soon.
                FM<><
                  Re: LED lights
                  I ordered some from superbrightleds.com. I will using them for interior lighting. I will get some pics up when they are in.
                  71 Bronco
                  EFI, ZF, Atlas 4.3, 35" BFG's, Explorer serp, hydroboost, 4 wheel disks, Lars Bars, Protofab bumpers, Warn winch,
                  Mastercraft seats.
                  Build thread
                  ZF swap
                    Re: LED lights
                    pics would be good. I was thinking interiors for starters. Then the exteriors.
                      Re: LED lights
                      I've ran the 1157 and other standard exterior replacement bulbs for years. Love-em, just a brighter light with less of a draw. The big draw back to led's is If you run in the snow the led don't heat up like standard bulbs, so you get snow pack on your lights.
                        Re: LED lights
                        When used in tail lights, it helps when your lenses are either in pristine condition, or new. If they're old and fogged up, you tend to get one big red spot in the middle of the lens, but not much "fill-in" like you would get with a normal bulb. Especially if your reflectors are, like most are these days, very dull. Since LED's are very directional, your reflector doesn't have as much to work with. Some bulbs come with side-facing modules for these reasons too. To get more spread inside the lens-and-reflector.
                        What setup do you have Ground Hog? And what brand of LED's? I've found that some are definitely better than others.
                        One thing I found that helps (reflector-wise) is to paint them a bright white color. Although I haven't tried an actual chrome paint yet, I did try "aluminum" paint, that was pretty shiny and it wasn't near as reflective as the white.
                        I even tried lining the reflector with that super-shiny chrome tape, but that was a bust too. The white worked best.
                        Interested to hear what your setup is like GH.
                        Paul
                        Wild Horses 4-Wheel Drive
                          Re: LED lights
                          I use the roundeyes rock lights. I love them!
                          WT 4x4
                          91' One Ton Bronco
                          1971 Bronco
                          9/11/01 Never Forget
                            Re: LED lights
                            Did you buy the 5 light set?
                              Re: LED lights
                              Yeah but it was a 6 light set. i just wired them into a series. They pull very little amps!
                              This kit in white.
                              http://www.roundeyes.com/LED_Lightin...Light_Kit.html
                              WT 4x4
                              91' One Ton Bronco
                              1971 Bronco
