I'm just getting to the install of my aerotank. It's an efi version and came with a bag of parts. There is a large o-ring included that looks to be sized for the fuel pump/pick-up fitting/compression ring. I'm running an external pump on the bronco.
Do I need to open the fuel pump/pick-up fitting and 1) install a "sock" and 2) redo the fitting/ring with the o-ring in place?
The write-up that came with the tank isn't completely clear and I don't want to start dismantling this thing if not necessary or introduce a potential leak.
Thanks, Tim
Thanks, Tim
