Anyone taken there bronco to an alignment shop? If so witch one? Got the 37's on and it wanders a little.. I think i need to adjust my toe in a little.. But now I am wondering about my other parameters.. Is there an easy do it your self home guide? Maybe I am just being picky.. But it does ride like a Cadillac..
Alignment shops?
Re: Alignment shops?
Aaron, any alignment shop should be able to at least tell you where you're at. The most they can do is adjust your toe-in but getting the camber and caster readings can tell you a lot.
I took my Bronco to a local mom-n-pop type place and they told me exactly where I stood, and adjusted the toe for a very nominal fee. You can try setting your toe with a tape measure but I think its worth having it checked out at a shop. Mine handles MUCH better after having the toe set - it was set too far in and was a little over-reactive on twisty roads.1970 Bronco
Originally posted by CityHick View PostAaron, any alignment shop should be able to at least tell you where you're at. The most they can do is adjust your toe-in but getting the camber and caster readings can tell you a lot.
I took my Bronco to a local mom-n-pop type place and they told me exactly where I stood, and adjusted the toe for a very nominal fee. You can try setting your toe with a tape measure but I think its worth having it checked out at a shop. Mine handles MUCH better after having the toe set - it was set too far in and was a little over-reactive on twisty roads.KK6DAD
Broncos dont need alignments, you just rotate the tires every 1000 miles{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....Originally posted by CityHickI don't give probabilities in percentage format anymore
bob at o.k tire on east bidwell in folsom does great work too. he gave me his caster shims for my hpp 44. i took the two highest ofset ones allready. i collect them at p-n-p and give them to him. he will even patch weight tires for the guy that has to have it perfect. i have a magnetic c/c gauge for the diy'er like me.6 jeeps 2a-cj5. bronco now. 70,efi 302,c4,ps,pb, 4.56's detroit's 2bl,4.5 rollin on 37's
