I have the motor mounts that raise the motor a bit. I have a stock metal hood with old school hood bubble. I have a two inch body lift. If I add a phenolic space to the intake will I need a new hood? How much room do I have?
Hood Clearance Explorer EFI swap.
Re: Hood Clearance Explorer EFI swap.
Good deal. Thanks. I was really looking for a reason to buy a fiberglass hood. Mine is falling apart and the fiberglass is lighter.
Change equal how much weight?
Aluminum heads, intakes, and water pump. Fiberglass hood, winchline over cable, and headers over stock cast exhaust manifolds.
I'd say net 100+ lbs. Maybe 150Don't worry about it...its mostly glass...will be fine...
I went to the woods to live deliberately...
Carpe' Dium
