Anyone have an opinion on the stock oil pump in the explorer 5.0? First, is it the same as all 5.0 motors? And if so, when is it wise to bump up to a better pump? What would you recommend...if you think changing it is wise? Here's the motor...
89 Explorer 5.0 bone stock block bottom end
AFR 165 heads
Roller Rockers
Ported GT40 Lower Intake matched to the heads
90mm Lmaf sensor
Stock Trottle body...65mm...may change this when I tune on dyno
30# Injectors...a bit over kill, but tuning allows me to control them
1.5" primary BBK shorty headers to 2.5" collector, ported for better flow
Motor will be run with 1993 A9L mustang computer with a moates quaterhorse added and software to tune.
Hoping to get 340 at the crank, but since the dyno will be at the wheels...not sure. I don't know how this drivetrain will eat up the numbers.
What do you think this motor will make number wise?
Now...assume the above motor gets a stroker kit to 347. What numbers then?
Now...assume a supercharger with 6-8 Lbs of boost...but then It goes in a mustang drag car? Oh...and I'll need an aftermarket block to avoid a big boom.
I can't believe I'm thinking of selling the Bronco but I seriously am..
AFR 165 heads
Roller Rockers
90mm Lmaf sensor
![Afraid7](https://www.norcalbroncos.com/forum/core/images/smilies/afraid7.gif)
