Looking to get some good info from the pros on the site. I have a 69 bronc that I'm trying to stuff a dana 60 axle into. The knuckles and tubes are from a 77 dana 60 and the case is a 79 HP case. I had the tubes machined a little to be able to press in the tubes into the case. I will need to get an alignment bar but wanted to ask about the correct angles that need to be set for the pinion and the knuckles. More importantly, I also wanted to know where I need to set the spring cups at. Is it ok to for the springs to be bowed a little. This is what the cage arm install instructions says to do. Do I need to push the cage arms all the way out to the knuckle and tack? [IMG][/IMG] Let me know what you think about the project. It's taking some time but I have had little time to work on it. Thanks for the input. I 'm more of a hot rodder but trying my hand on a little nasty bronco.
http://www.flickr.com/photos/21034245@N02/5253446668/
[IMG]
http://www.flickr.com/photos/21034245@N02/5252835983/in/photostream/[/IMG]
Thanks,
GB
[IMG]
Thanks,
GB
