starts up and runs fine..but when i let off throttle it dies ..starts right back and runs good until i let off throttle than it dies..that the throttle control sensor? car in on an incline in driveway that make a difference..it ran fine when car was on level ground..any input would be appreciated...
86 5.0 motor
Re: 86 5.0 motor
Originally posted by Nuchi View Poststarts up and runs fine..but when i let off throttle it dies ..starts right back and runs good until i let off throttle than it dies..that the throttle control sensor? car in on an incline in driveway that make a difference..it ran fine when car was on level ground..any input would be appreciated...2002 F250 Superduty, 7.3 241,500 miles and counting
Re: 86 5.0 motor
car has been sittin for a while..gas could be bad, i know he added some but might have had some remnents of old gas in it..ill pulled one plug to check it and looked like it was burning ok..ill check the rest..ill change fuel filter..and cap tomorrow..thxs for the suggestions..ill check them tomorrow
Re: 86 5.0 motor
Originally posted by Nuchi View Postcar has been sittin for a while..gas could be bad, i know he added some but might have had some remnents of old gas in it..ill pulled one plug to check it and looked like it was burning ok..ill check the rest..ill change fuel filter..and cap tomorrow..thxs for the suggestions..ill check them tomorrow2002 F250 Superduty, 7.3 241,500 miles and counting
Re: 86 5.0 motor
Originally posted by Nuchi View Postno code reader, but i hear there fairly cheap to buy, is it worth buying ?2002 F250 Superduty, 7.3 241,500 miles and counting
Re: 86 5.0 motor
Underneath the upper plenim is an idle stop just like carbs. Have you tried to screw it in some?Dana 44 w/ ox locker, yukon axles, T-bird disc brakes. TBI 351 W, Saginaw p.s. & rock ram steering assist and F150 steering gear box. Manual dual chamber master cylinder. AOD with supercoupe 1st & 2nd gear. The t-case(S) are a 203/205 combo. Rear diff 5.13 detroit locked tru hi 9" with 35 spline axles in a big bearing housing. Suspension is a 5.5" lift with a one inch body lift. Inside two radios are CB and Ham radio (KI6CYF).
