I am looking for someone to confirm my suspicion, and help me buy the best replacement parts. I have a 71 bronco with a stock disc/drum master cylinder and an astro-hydro boost set up. The brake pedal has been creeping towards the floor when holding at a stop light. The dash brake light went on, but went off after a stab on the brake pedal. Today the brake pedal went all the way to the floor during normal driving. This all started when I was pulling someone out and had my brakes pushed down hard while winching.
I suspect the master cylinder seals are shot, as there is no brake fluid leaking any where. Is there any chance it could be the older used hydroboost unit?
I am planning to replace the master cylinder, but wanted to get some feedback before I start replacing one part after another. Assuming it is the master cylinder, are there any good candidates for new ones? My old master cylinder and the hydroboost has different bolt spacing which has been re-drilled so I can go either way on the master cylinder. I may want to keep the door open for a rear disc upgrade someday also, but I would hope a disc/disc master would work for a disc/drum.
I miss my brakes…wow that sounds stupid, but the hydroboost was a huge improvement to my brakes. So much so I may not do the rear disc swap if I can get them going well again.
Thanks for you thoughts and advice.
Dave
Dave
