When I was at Praire City I noticed there are more than a handful of you that aren't using the aux gas tank. I get the whole rocker panel reason but thought that the "GREAT" gas mileage most of use who drive to the trail are getting would out weigh wanting to do away with the extra fuel by removing the tank. I hadn't ever even thought about removing the tank because I thought that gas would be too valuable by the time you drove to the trail, did the trail, then had to find the nearest gas station. So now I'm considering removing the tank for more rocker protection and wanted to get a general concensos. Is it a pain in the ass having limited range when using only one tank? Those of you running one tank, about how many miles are you getting out of a tank? EFI, carburated, whatever, Im just trying to make a decision. Yes I know we can carry Jerry cans.
EDIT:
I've read about three replies some for the tank and some not for the tank. So, does anyone make a aux tank that holds less fuel and is shallower for more underside clearance? I'm running an aftermarket 23 gal out back.
EDIT:
