Ok Everyone,
I did a good deal of searching through older posts and got bits and pieces for what I need. I know the information is probably out there but here are my specific questions.
What I have now:
-Dodge 5.9 L 4x4 gas nv4500 (part number 53006845).
-ford 302 refinished fly wheel
-Dodge shifter (will this work still)
-Just ordered the transmission to transfercase adapter:
http://www.advanceadapters.com/products/pn-sy-50-0209/
-$600-700 (more if absolutely necessary)
Here is what I know I need:
-A new clutch and throw out bearing
-Adapter for bellhousing to transmission
-WH cross member kit
-Drive shaft modifications (these are on hold)
Swap Questions:
So what else do I need? I am unsure about pilot bearings and about what other stock stuff I can reuse. I talked to WH guys and that said that the Knightmare bronco uses a manual clutch for their nv4500. So I figured I'd go that route if it was possible (and prob cheaper).
Transmission Questions:
I took the top off the transmission and it looked good. Very fine metal dust on the magnet on the bottom of the transmission but nothing larger then even a grain of sand. Has all the teeth of both gears and syncros. Can shift in and out of every gear. I am nervous about getting the right oil for the transmission. Recommendations there would be awesome too! (I know some of you recommended the castroal stuff, but anything else). What (if any) sealer did you use for the transmission to transfer case to keep the oils away from each other?
I have about four weeks to get this bronco's frame and body back together. I have to wirewheel the undercarriage and herculier it, install a two inch body lift, and get this transmission figured out, before we move (bought a house and my wife is not super happy that our bronco has now become part of our new house remods budget).
Special thanks to Justin (Trailbound), he found the CL listing for me. Got two NV4500s bellhousing to transfer case for 300 bucks a piece!!!! Sold one NV and the two transfer cases so I can put whole thing together on the cheap. Norcal Bronco Buddy of the Year award (Do I smell a new thread idea).
Thanks again for all the help guys. Especially Justin and Patrick letting me bug them all the time. I love this site!
What I have now:
Swap Questions:
