Im thinking of ditching my 5/16 Ford Nylon Fuel lines and going either Stainless or Aluminum fuel lines along the frame rail with Steel braided lines going to the Spring Connectors on the fuel rail and going to the Sherman Tank.
Couple questions.
Is it better to go 3/8 Feed and 5/16 Return or can I do both in 3/8? Trying to avoid buying excessive lines since it comes in coils of 25ft.
Also, Is Stainless Better than Aluminum? Aluminum is half the price?
With aluminum you can use the Nut/Sleeves correct versus double flaring adapters?
Everything will be connected via AN6 Fittings including an inline Fuel Filter with An6 fittings.
Im running the Sherman Tank with in the tank Pump. EFI
Couple questions.
