Re: Fuel Lines
Agree with Doug. The basic 5/16" nylon tubing in my Bronco worked just fine for the 26 years it was in my Bronco. Now I'm plumbed with a mix of rubber hose/hose clamps, Ford push-on/barb connectors and stainless steel tubing (engine compartment). It's been that way for 10 years and 60,000 miles. I've replaced a couple of rubber hoses that were starting to look ugly, but otherwise it's been trouble-free.
For what it's worth, the "AN" fittings most of us buy aren't. They are JIC. Almost the same, interchangeable (unless you are working on certified aircraft) but not identical. Automotive fitting suppliers use the term, but AN means class 3 rolled threads (JIC is nominally class 2 and can have cut threads, though most fittings are rolled) and tighter tolerances. AN fittings, such as from Aircraft Spruce, are spendier. Oh yeah, and AN/JIC flare angle is 37°, not 45°, and is normally single flared![Smile](https://www.norcalbroncos.com/forum/core/images/smilies/smile.png)
If using aluminum tubing I'd advise supporting at least every 12" with adel clamps or similar. Vibration kills aluminum tubing. Also, a lot of the easy-to-bend aluminum tubing is 3003 alloy. 5052 is more expensive and somewhat harder to bend, but much stronger and flares better.
