I have centec wiring that is labeled but switch is not just 1-5,b??,w.=wash now , power,park,high,low,ground in what order is it, purple is wash but im not sure of others or B. anyone have this problem,also do you run a ground from the prong on push-in lighter on back of unit
electric wiper switch
Re: electric wiper switch
Originally posted by 66 twins View PostI have centec wiring that is labeled but switch is not just 1-5,b??,w.=wash now , power,park,high,low,ground in what order is it, purple is wash but im not sure of others or B. anyone have this problem,also do you run a ground from the prong on push-in lighter on back of unit
Got pictures of the switch? Never used the wiper switch that came in the centech kit... I always reused the plug from the factory harness and factory switch...2002 F250 Superduty, 7.3 241,500 miles and counting
Originally posted by 66 twins View Postthis is the wiper switch2002 F250 Superduty, 7.3 241,500 miles and counting
Originally posted by 904Bronco View PostWell being it comes wired in the harness from the factory and they do not supply a wiring diagram... and you have mounted it already.. I would probably get a continuity tester and figure out what goes where that way. The one tab marked "B" could be the battery. Unless someone has the harness still attached that could take a picture?1969 Sport, 351 roller EFI, 4R70W, TEAM BLUE.
Originally posted by 14Justice View PostHere is the way mine wired to me, new in box. This is looking at the back of the switch.The flat represents the flat spot where the bezel mounts to the front. (Hope that makes sense)Last edited by 904Bronco; 02-11-2012, 07:05 PM.2002 F250 Superduty, 7.3 241,500 miles and counting
Originally posted by garberz View PostIf you want a real challenge, try to figure out how the wiper park circuit works, then try to explain it to someone else.2002 F250 Superduty, 7.3 241,500 miles and counting
Originally posted by 904Bronco View PostBrad that is the Factory switch that you have, they have the GM one that came with the older kit... Still... good documentation with these pictures for those that upgrade to the factory switch! All those years writing PD reports and drawing diagrams came in handy...1969 Sport, 351 roller EFI, 4R70W, TEAM BLUE.
Bought in 01,so long ago. Yes I guess I have gm,mine is push 4 wash,so Ive left it alone and will call tech/research what i can for now,also electricity and me arent the best of freinds so can you test a switch and wires with somekindof tester 4 where they would be??? ,keep in mind build stage no wires are finished or batt. installed
