I've got my lower and upper flaming river steering yokes. The lower is a no brainer but I need some saftey ideas for the upper. If you look at the picture you can see where I'm at. I was going to weld the yoke/u-joint straight to the steering rod but if I do that it makes it impossible to
#1. Remove the steering wheel if I ever need to
#2. I can't service the steering rod bushings (in the steering column) or replace them if the need ever arises.
What would be the next best and safest way for me to attach my steering yoke to by steering rod?
I can drill it and tap it. The problem with that is that the yoke I got(and can't return now) doesnt' have a very large area for tapping, there wouldn't be very many threads. NOT SAFE by itself.
I can drill through the yoke and the rod and pin them together.
I can drill it and tap it and then add two small tack welds.
I could saftey wire something, however I've never used saftey wire.
Bottom line is that I just don't want to die or kill my family going down the freeway and loose all steering. Open for fail safe suggestions.
