Mr. R's rebuild
  • #16
    Me likey the bar
    Which one ???
    • #17
      VERY NICE WORK Bro! Can't wait to see how mine is gonna turn out!!
      • #18
        For you who are curious about a good way to remount you rear seat to your cage check this out. It works very well and the 4 bolts are easy to get to so removal is easy. Have a great day. FM
        • #19
          Very nice! Easy and clean yet not to difficult to remove. It doesn't get any better than that.
          • #20
            • #21
              Originally posted by lagox4
              .... Iron Mountain Road has my name all over it! Let me know when the Posse has trail detail...maybe you, Chuck and I can represent the EB in force.
              Is that Iron Mountain Road in Shasta County?
              Brad
              Chico, Ca.
              • #22
                No, in this instance, Iron Mountain Road is a stretch of Hwy near "Sly Park" which is just east of Placerville Ca.
                Great for "snow-wheeling" as the road isn't maintained during the winter months...it offers plenty of family fun.
                72 Sport
                • #23
                  looks good
                  • #24
                    More Pics!
                    Aaron
                    KK6DAD
                    • #25
                      Mr. R has it right now he is pulling the aux tank and a couple other things. Then we should get 'er back and finish the front seat mounts and the center over head switch panel then we will be pulling the cage out adding all the tabs and gussets and then final weld and paint.
                      Hey Aaron could you post the chevy 1 ton tre parts numbers - looks like I will be relocating the trac bar and doing a tie rod over flip. His got thrashed from having too much fun this year. Plus he has some cracks showing on the inside of the frame behind the steering box that we will fix and reinforce.
                      At the rate we are going and with all the changes I hope to have it done by Mar of 07 but I will try to get 'er together sooner so he can play in the snow with the rest of the kids
                      • #26
                        Famlyguy what kind of carpet is that.. i have been wanting to put something in there but i want something easy to get dirt and mudd out of. almost like the bed rugs for pickups.
                        ps the cage looks nice!!!
                        • #27
                          This is what I found:
                          ES2233L
                          ES2234R
                          ES2027L
                          ES2026R
                          Parts Mike has listings for all but the ES2026R.. they use 2 of the ES2234L..
                          Maybe the ES2026R are the sama as the ES2234L??
                          Trying to figure this out..
                          http://www.partsmikeparts.com/tre_kit.htm
                          Hope this helps!! Let me know when you do this I would like to do mine also.
                          Aaron
                          KK6DAD
                          • #28
                            Thanks Aaron
                            71- dont know maybe Lago will post up .
                            • #29
                              Well she is just about finish welded. Got the bottom side and most of the top. Have alittle more work todo but got in most the tabs and gussets. On the final stretch...............................
                              • #30
                                Very nice Chuck! That is a lot of welding, huh. You don't realize how much welding it is, until you do it. Looks awesome, nice work!
