For you who are curious about a good way to remount you rear seat to your cage check this out. It works very well and the 4 bolts are easy to get to so removal is easy. Have a great day. FM
Mr. R has it right now he is pulling the aux tank and a couple other things. Then we should get 'er back and finish the front seat mounts and the center over head switch panel then we will be pulling the cage out adding all the tabs and gussets and then final weld and paint.
Hey Aaron could you post the chevy 1 ton tre parts numbers - looks like I will be relocating the trac bar and doing a tie rod over flip. His got thrashed from having too much fun this year. Plus he has some cracks showing on the inside of the frame behind the steering box that we will fix and reinforce.
At the rate we are going and with all the changes I hope to have it done by Mar of 07 but I will try to get 'er together sooner so he can play in the snow with the rest of the kids
Famlyguy what kind of carpet is that.. i have been wanting to put something in there but i want something easy to get dirt and mudd out of. almost like the bed rugs for pickups.
ps the cage looks nice!!!
This is what I found:
ES2233L
ES2234R
ES2027L
ES2026R
Parts Mike has listings for all but the ES2026R.. they use 2 of the ES2234L..
Maybe the ES2026R are the sama as the ES2234L??
Trying to figure this out.. http://www.partsmikeparts.com/tre_kit.htm
Hope this helps!! Let me know when you do this I would like to do mine also.
Well she is just about finish welded. Got the bottom side and most of the top. Have alittle more work todo but got in most the tabs and gussets. On the final stretch...............................
