In regard to a limit strap you can also just weld a tab to stop the swing of the carrier. I have done this on the last 2 and it works great but I would like to see what you come up with especially if it is adjustable.
FM <><
FM <><
I initially was going to just do the tab and maybe even have a pin that would hold it open. I am only considering the limit strap so it would double as a safety in case the spindle did give the rack and tire wouldn't fall off going down the highway, just to be on the safe side.
I think my spindles will have to mount over the top of the tube about where the bend starts, do you think it would be wise to drill the 1.25" hole through the 2" tube, I was thinking it needed to go through some type of plate gusset like you described as well?
As far as the spindle braking, the few pictures I saw on Pirate they snapped right where the spindle tapers down for the lower bearing. One of them happened while the gate was closed and driving down the freeway (or so they claim). Like I said before ,I know a lot people that have used these for years, so who knows. My guess is the ones that broke were most likely due to the tire hitting something on the trail which damaged the spindle and it just broke off later???
