Project Crawlin68
  • Wow,
    Looks like Christmas in February, every thing you need to Act a Fool...
    • Originally posted by 720Racer
      That's me!!!
      • So that's where all my parts went. I only got one long side inner today.
        • Why the new knuckles? Are those better than the stock knuckles, or was something wrong with the those rusty old knuckles?
            The stock Ford steering knuckles are notorious for cracking (see picture) especially when you run high steer arms and 40 inch and larger tires. My stock knuckles are just fine (no cracks) This is a picture that I found on Pirate of the weak spot.
            I just want to build this axle one time and never have to touch it again. So...Mr. Overkill strikes again and I just figured I would install the Dedenbear knuckles now and sleep peacefully at night.
            • Originally posted by 69crawler
              Ha! Yeah the UPS guy must have made a wrong turn and ended up at my house.
              • OK, now I have to go check for cracks. Anything else?
                • Just check for those cracks, but if you aren't going to run high steer arms and big ass tires, you probably don't have anything to worry about.
                  Did you find the BOM?
                  • Originally posted by Mr. Overkill
                    .....but if you aren't going to run high steer arms and big ass tires.....
                    37's the new 33's or what? I don't see any cracks..........yet.
                    • BLING BLING! CTM's and Orange parts!
                      Thinking of selling your stock kunckles? I always need spares
                      • Originally posted by welndmn
                        Yeah, I will be selling the stock knuckles, axle shafts w/u-joints, carrier w/ring and pinion and the Ford locking hubs if any of you guys want trail spares.
                        • Geez...after this it will be time to stop spending $$$ don't u think?
                          I haven't heard of the knuckles cracking. Do you think I will have an issue with the ones I just bought??
                          • Originally posted by Delta 4 Wheel
                            .....after this it will be time to stop spending $$$.....
                            You mean at some point Broncos become less expensive? I'm confused.
                            • Geez...after this it will be time to stop spending $$ don't u think?
                              Not likely, he still has the itch for lower gears, and a 4-link rear.
                                The cracking issues are with the D60 knuckles not the D44 knuckles. It might just be a product of people running larger tires on rigs that have D60 front axles, therefore, causing the cracking. Most people running D44 aren't running super large tires. (40's and up) So they are not experiencing the cracking problem.
