Originally posted by crawlin68
View Post
Project Crawlin68
Originally posted by silverhorse View PostNice job Patrick, A buddy of mine had the junk version "cast" unimog axles. He broke the reduction housing the first time out. I suppose you know which ones are the better version?
A lot of the portal boxes are cracked just from their military use, so you need to look at them real close once they are imported to the USA to make sure you are not buying a cracked set.Last edited by crawlin68; 12-16-2007, 09:02 AM.
Originally posted by crawlin68 View PostAll of the unimog portal boxes are cast. The 404, 406, 416's, all of them. The trick is to braces them so you don't get the gear deflection. That is next on my list of things to do, so pics will be on there way!
A lot of the portal boxes are cracked just from their military use, so you need to look at them real close once they are imported to the USA to make sure you are not buying a cracked set.Are you going to pull those pistols or whistle dixie?
Originally posted by silverhorse View PostI see, my buds looked brand new. He broke one on the first trail we went on. I would brace them well! Can't wait to see the pics.
Originally posted by crawlin68 View PostDo you know which axles he had? Was it the original unimog axle or a hybrid axle? What part broke? The portal box casting? The unimog axles have another weak point too. The shifting collar that shifts the locker in and out is known to break at the most inopportune time leaving you with an open diff.Are you going to pull those pistols or whistle dixie?
Beautiful work man. After checking out a true hi nine, I've been researching flipping my 3rd member as well. Looks great!!1973 Bronco Ranger - 302, C4, Dana 20, Dana 44 front, 9 inch rear, 3.55 gears, 35" MTR's on Allied Beadlocks, 3.5" Wild Horses lift
Originally posted by GloNDark2 View PostBeautiful work man. After checking out a true hi nine, I've been researching flipping my 3rd member as well. Looks great!!
I finally got those darn hubs off of the portal boxes. Man were they a b$tch to get off. I would bet that they hadn't been removed for 40 years! First I took them to a local machine shop and they put it on their 40 ton press and that didn't even budge them. Second I took them to another local shop that had a 50 ton press, no go. They didn't budge. So I brought them back home and built my own little home brew press using a bottle jack. (Try to keep the laughter to low rumble) But when I put some heat on it with my rose bud.......presto! I got them both off! Then I cut off the outer ring because I will not be using that. I've got a new hub flange that will give the 8 on 6.5 bolt pattern that I will be welding onto the center part of the stock hub.
Glad to see you didn't get hurt, a multiple of things could of gone wrong. How many tons is your bottle jack rated at? I can see the deflection in the cross bar at the top!
LOL! Yeah I guess my welds held. Not bad for little 110v 135 Lincoln machine. It's a 12 1/2 ton bottle jack and I think that I about maxed it out. I put about 4 foot cheater bar on the jack handle and was leaning on it pretty good. The top of the press deflected A LOT more on the second hub than the picture shows. The top piece is 1/4 inch thick, then I put two more 1/4 inch thick plates between the jack and the top of the press, so it was bending the crap out 3/4 inch of steel.
Maybe that's why so many people crack mog boxes, thay have to almost destroy them to get the hub off.
Did you find someone to turn the hubs down yet, Or are you building a lathe out of whatever you can find in your garage right now.Last edited by highlander; 12-18-2007, 06:36 PM.69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
Originally posted by highlander View PostDid you find someone to turn the hubs down yet, Or are you building a lathe out of a lawn mower and whatever other parts you can find in your garage right now.Marc D.
You guys know me too well. I have been scheming in my little mind how the heck I can turn those down myself with what I have in the garage. You don't even want to hear the ideas that I came up with. I think I would make Maguver proud!
I think I decided that I need to find someone with a lathe.
Originally posted by crawlin68 View PostYou guys know me too well. I have been scheming in my little mind how the heck I can turn those down myself with what I have in the garage. You don't even want to hear the ideas that I came up with. I think I would make Maguver proud!
I think I decided that I need to find someone with a lathe.69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
I think I decided that I need to find someone with a lathe.Marc D.
