Ive been working on it for a while now ever since the last time i was wheelin and the coil spring screwed me over and my fan ate the radiator....... so i bught a Taurus electric fan and an aluminum radiator......... next is aluminum intake and new heads, headers, fender flares, spray on bedliner the whole interior and underhood, new bumpers, and a traction bar of some sorts.....
Bronco update
oooo aluminum!!! looks nice
and im glad im not the only one using my phone as a camera{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....Originally posted by CityHickI don't give probabilities in percentage format anymore
Looks awesome. I like that you cut the core support out completely...I wished I would have done this on the rig in my garage...I needed more room then the 1.5 inches I cut out. Nice work.“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
Originally posted by Delta 4 WheelLooks awesome. I like that you cut the core support out completely...I wished I would have done this on the rig in my garage...I needed more room then the 1.5 inches I cut out. Nice work.1970 Bronco
Well i worked on it a bunch last week. Stripped the front end and repainted everything gloss black, 1.5" wheel spacers, did a spray on bedliner which turned out great, and got my fender flares on today Finishing up the body work tomorrow.... here some pics...
]--'73 Bronco----302, 3 spd, D44, 9", Tru-tracs, Twin sticks, 5.5" National Soft ride coils, F-100 pwr steering, 35x12.50's, tilt column, hurst shifter
X2 - what kind of bedliner did you use? A DIY kit of some type I presume? The local paint shop sells two types that are both spray-on, one requires a special gun that they will rent out, the other just uses a standard Schutz type gun... I'm curious if its one of those.1970 Bronco
X4!!! I'm wrapping up my floor replacement and this is next. That looks great!
http://www.rattleguard.com/INDEX1.htm69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
Very interesting... I've got lots of experience texturing sheetrock - my house (only a couple years newer than my Bronco) was my project before I had my Bronco. If rattleguard truly applies from the same hopper as sheetrock texture, then I already have the necessary equipment. I may have to look into this. I do like the line-x/rhino idea for the warranty and level of experience you're paying for by having them apply the product. We'll see.1970 Bronco
