Project Treethumper
Another neglected EB has found a good home where it can be rehabilitated! Congrats, this looks like a fun project... You've got some ambitious plans and I look forward to seeing it come together.1970 Bronco
Originally posted by 720Racer View Post37's, 4 link and a injected 5.0. Should be a good build. Full width or EB width axles?It's a project. 4-link front and rear 37's fuelie 5.0
[QUOTE=TREETHUMPER;30624]This is my new project we just picked up sat. Price was right. 1968 u15.Planning on doing 4-link front and rear. King coilover shocks. Most likley 37" tires but that may change. I can't decide to go 39.5", 38.5", 37", or 35" tires. Also putting in fuelie 5.0.
You have your work cut out for you. Have fun. I had less to start with when I started.
I went with 35's and regret it. Sure wish I had gone with 37's. Once I get the money needed I may be selling the 35's and going bigger.
JeffVacaville, Ca
Treethumper is my son-in-law, for those of you that didnt know that. this is going to be an interesting build to say the least!!!!Trailbound (my son) found this beauty on CB in madera and we brought it home for a grand. its straight, rusty rockers will be cut off for sliders, floor pans will get glassed. its really in not too bad of shape. all it takes is $$$$$$ as we all know!!! POPS72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
My main questions for starting with the four link would be how to find the center of gravity height and how tall the bronco should be running 37" tires (frame height). I am going to start measuring for everything starting next week after we get the body off and motor and tranny out of the bronco.It's a project. 4-link front and rear 37's fuelie 5.0
Originally posted by TREETHUMPER View PostMy main questions for starting with the four link would be how to find the center of gravity height and how tall the bronco should be running 37" tires (frame height). I am going to start measuring for everything starting next week after we get the body off and motor and tranny out of the bronco.
I have ~5.5" SL and 2" BL w/ 37" tires. The bottom of my frame is 24.5" in the center, 29.5" over the rear axle and 31" over the front axle. If I did it again I would cut more and run less lift. Extend the rear wheel tubs and extend or remove the fronts. I would also stretch the rear out as much as possible.
The center of gravity height is tough to calculate, but most people use the height of the crank center-line as a guess. I used 36" the height of the crank at the bellhousing.Last edited by highlander; 11-07-2007, 03:45 PM.69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
