project: never ending project
  • project: never ending project
    I'm finally posting some pics of the 74' build.I Bought the bronco 7/5/03,drove it home and immediatly started taken her apart.
    Are you going to pull those pistols or whistle dixie?
    Nice lookin rig. Looks like a good starting point. What are your plans for it?
      The drivetrain is already finished. I'll post more pics of the build first chance I get.I'm now toying with the idea of welding my cut rear quarters back on!!
        6/12/04 Here are some shots of the cut out floorboards.The tub is on a rolling dolly.I have since ended up replacing a taillight section(very fun),rocker on one side and a door post.
          Here are some drivetrain pics.
            Just a nice street/trail bronco. Mostly street.
              Rolling chassis looks awesome! How much lift did you do?
                Thanks! its Wild horses 5 1/2''. I figure with that much lift I can run the 33's with uncut fenders if I decide to weld them back on.I'm really starting to like that original look.There is a guy from Alberta, B.C. in Bronco driver issue #11(readers rides section) with 36'' tires and uncut fenders and it looks sweet. I'm not sure how well it will function but like I said it's mainly a street truck.
                  Looking good so far! Isn't all that rust fun and pretty much normal in most of these now a days? I will be keeping my 71 as an un-cut street rig as well. I have to replace the quarters on mine due to the PO cutting then out but luckly no rust can be found (that was the only reson I bought it). With the 5.5" lift how much room would you have to the un-cut fenders if you were to put them back in? I want to run 33-35's but do it with as little lift as posible and no body lift. I am going to keep mine on the stiff side with sway bars to help out for street handling. Keep the pics comming.
                  Kevin
                  71 EB 56K original miles stock for now!
                    This is what mine looked like with around 5.5" of lift, and a 3 inch body lift. The tires measure out to be 33" tall. My suspension is really soft in the back, but when I would pull out, or in my driveway, the tires would hit the fenders. The plan was to cut them, so I just hacked away sooner. I do like the looks of the uncut broncos though. If you can figure out a way, do it.
                      Well, I'm almost wishing at this point I would have left the fenders uncut,kept a stock motor with a smaller narrow tire. I have seen some nice broncos with around 3'' of lift,uncut, with around 31'' tires that I thought looked really nice!My taste must be changing. I guess I have gone too far in the other direction to turn back now.
                        Any updates???
                          body/tub pics
                          here are some pics of the tub- It has been blasted,primed and seam sealed.Ready for paint if I ever get around to it!
                            Looks awesome...glad to see you gusseted your tub before you pulled it! A lot of people don't do it and regret it when things don't fin when it goes back together...
                              Coming along nicely. Looks like you've made a lot of progress. Keep those pictures coming.
