Re: BroncRider's 66 Bronco Project
The 2wd 435 has the proper flange bolt pattern as well as the correct output shaft. All that is needed to prepare that tranny for install is to zip cut the speedo drive from the tip of the output shaft. I would seriously look for a used adapter. The adapter is much more than a flange adapter. It has included in it an adapter that fits into the transfer case to accept the splined shaft from the tranny. You should be able to find one for a few hundred. I don't know much about building one from the 6cylinder adapter, but that sounds like a good option too. Not too sure what is used for the tcase portion of the adapter though.
Originally posted by BroncRider
