So, I figured I would actually start a build thread, since Ive never actually kept up with these on my projects, just reading others.
I traded my Cummins powered 2000 F-250 on 38's, etc, etc... for this beautiful 73 Bronco... always wanted one.
According to the PO:
414W Stroker
-Forged Eagle Rotating Assy
-Keith Black Forged Pistons
-H Beam Rods
-Milodon Pan
-AFR 205 58cc Heads
-9.5:1 (seems low to me with flattops and 58cc heads, but w/e)
Built C6
-3500 stall converter (ack)
-6 Roller Planetaries
-Auto Valvebody
-POS B&M Ratchet Shifter (that I promptly threw out of the rig when I got home)
-Art Carr Shifter
NP205
-Apparently a short 5" adapter from a 203 (just so the cable on the Art Carr shifter wouldnt work correctly, so I need to make a new bracket)
-plan to twin stick it, or put my other rebuilt 205 in that is already twin sticked and ready to go
D44 Front
-Discs
-Yukon Axles
-Warn Hubs (silver tho, not gold... prolly change out)
-Trak-Lok L/S
-F150 Steering with Heims
9" Rear
-31 spline Yukons
-Detroit Locker
-4.88's
5.5" Lift (yellow coils?)
1" Body lift
37" Boggers on 15" Aluminum Beadlocks
Plans:
Im using it as a daily driver for a 15 mile commute and also want to be a capable crawler.
Eventually, 4 link rear, 3 link front, and coilovers. EFI the engine, change the stall in the converter, get more tcase gearing, build a better cage, line-x the tub, build a dash with the autometers that I have, 12voltguy switch panel, suspension seats, etc...
Im just really happy to finally have a bronco. Ive spent countless hours on pirate4x4 reading about builds and tech, so I am always modifying stuff and hoping the bronco will make it even better!
More Photos at Link:
http://s264.photobucket.com/albums/i...x/73%20Bronco/
![](http://i264.photobucket.com/albums/ii175/slprlx/73%20Bronco/th_LEFT.jpg)
and yes... the golfcart stickers came off as soon as I got home with it...
414W Stroker
-H Beam Rods
-Milodon Pan
-AFR 205 58cc Heads
Built C6
-Auto Valvebody
-Art Carr Shifter
NP205
D44 Front
-Discs
-Yukon Axles
-Trak-Lok L/S
9" Rear
-31 spline Yukons
-Detroit Locker
-4.88's
1" Body lift
Plans:
