Latest Creation--Rear 9" Gusset
  • Latest Creation--Rear 9" Gusset
    After replacing my rear leaf springs and u-bolts, I came up with this using 2 X 4 188 wall tubing.
    Leave No One Behind
    KK6AUW
    Re: Latest Creation--Rear 9" Gusset
    I gotta learn to weld. That looks good.
      Did you use an alignment bar and pucks to keep the housing straight?
        Looks sweet man! Nice and clean. Like Gil asked, did you use some kind of alignment bar or stitch weld it to keep the heat down so as not to warp the housing.
          I want one..
          KK6DAD
            I did the stitch weld method, plus the criss cross apple sauce @ 2-2.5 in length, so not to much heat would be introduced at one time. End to end it took about 6 hours between welding and cooling. Aaron you got it dude!
            Leave No One Behind
            KK6AUW
              You might still want to check it with an alignment bar and pucks. if your off as much as 1/8 even 1/16 the axel is toast...I did the same in a car i put a 9 in and was off 1/16'' didn't get 500 miles out of it...
              75 sport 302 c4 full width 44 front 9 rear let the building begin
                I don't have a bar and pucks to check it. So what I did is clamped two straight edges on both axle flanges and took measurements, and rotated the stright edges. End result, I checked it 360degrees. And it appears to be right on. Since install I've clocked over 1500 miles.
                Leave No One Behind
                KK6AUW
                  I wanted to say the Shaffers off road is now cutting these back braces that go from axle bearing to axle bearing on his torchmate for a damn good price.
                  I'm sure after spending all that time making one you'd agree they are worth it to buy.
                    True that! But I had a blast doing it myslf.
                    Leave No One Behind
                    KK6AUW
                      Built not bought. It looks sweet.
                      They flex like a boneless hooker
