Christine
  • Christine
    I have decided that all the rust is holding my bronco together good enough for now, so I am going to rewire ol christine first. here is my progress.
    Re: Christine
    You got more balls than me, would like to do mine. But afraid to.
      Re: Christine
      this is the same harness that I put in my cobra so hopefully I can remember how to do the hard parts. and painless had a 100 dollar rebate so I went ahead and jumped in.
        Re: Christine
        Wiring is easy... It is the troubleshooting that is a Bi#*h
          Re: Christine
          I will refund you check and you can wire /troubleshoot mine I will even throw in the Alt.
            Re: Christine
            Becareful......Mine started out as a "Re-Wire"....it's been down for 3 years and has turned into a complete rebuild!
              Re: Christine
              Well, 2 weeks and counting. Hope it doesn't turn into 3 years.
              I did build a glove box today though, even with my 5 year old daughter sitting next to me asking questions non-stop.
                Re: Christine
                I had an electrician tell me the thing to remember is a wire has two ends. I got that part down. Then I found a wire that had three ends.
                Just a stock 1966 U13, 170 ci 6 cyl, no kiddin'.
                  Re: Christine
                  I buckled down the past two days and got the first of the hard parts done. I moved the fuse block so its facing out where you can see them. Doesnt look perfect but its all got come out again to be painted later anyway.
                    Re: Christine
                    took my bronco for the first test drive after installing the wire harness. Not too bad, the only trouble shooting I have to do is on the wipers and the fuel gauge. I am pretty happy.
                      Re: Christine
                      No smoke is GOOD!! YOOHOO!!!
                        Re: Christine
                        That is inspirational, and I need inspiration. Nice work.
                          Re: Christine
                          yup, three months with a total of about 12 hours of actual work. I am inspired too, what should I "fix" now?
                            Re: Christine
                            How is your steering column?
                              Re: Christine
                              the column is decent, I replaced the turnsignal switch and now All i need for that is the hardware that holds the horn button on.
